I just bough a sony xperia arc s, My native language is Farsi and I have added that in the setting/language/writing international blah blah, but when I want to type a new message there is only chinese and english available, chinese is everywhere in this cell and I want to completely remove it. even in the home menu the gallery is written in chinese, that is so annoying to me.
I have not updated my phone to 4 yet and I'm not planning to do it for a few weeks ahead until I get it straight
ah, I mistaken the build number with android version :smileygrin: okey I'm downloading flash tool and the firmware to see if I can get released from this stupid thing or no?
thank you a lot
No problem, let us know how it goes
ok I've downloaded the latest version of flashtool and the version of android you have been mentioned, but when I run the flashtool the branding is two squares!!! I'm afraid this does not return the phone in the chinese stuff again
it's the global generic firmware
I don't understand what is wrong with this one? It says the debug mode is off when but it's checked!!!! it seems that changes I make in the options does not take effect!! What should I do now?
what are you trying to do? did you finished flashing?
I'm done, flashing with the global did the trick. thanks a lot
Anytime, keep an eye on this work in progress thread, so you can flash Android 4.0.4 (not the buggy 4.0.3) it will be released next week (last week of May)
http://talk.sonymobile.com/thread/38251
