best. I wonder because my sony xperia t Turn taking 50% of battery. and then begins to restart. I expect a prompt reply, THANKS
It could be a hardware issue, I have a similar issue with my Xperia T, so try this
1) restart your phone on safemode and use it until the battery goes bellow 50%
if that doesn't work
2) repair your phone with SUS or PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
not work. still goes out
In that case you have to stop by a Sony repair center as it might be a hardware issue
could be the battery?
@sanah,
The best solution for you is to visit an authorized service center and directly to find out what the problem really is.
Uli gave you the link.
thanks
