Hi. I have problem in the radio with the new software. The sound is not clear as it should be. Does anyone have an idea about this?
I do not understand when I install the SUS. Does this mean that I will not be able to install any app at all?
no, it means that it will delete all apps and everything else, and then you can test the Radio w/o installing any app and deleting mcafee
The problem has not been solved. Anyway, thank you all.
Sony have now responded to this problem http://talk.sonymobile.com/thread/44397?tstart=0
IAn
Hai Johan,
I am also facing the same problem, my fm is not working well it is very noisy and i am uable to hear the speach, before ics update it was working fine, i tried with different headset still it continues, please fix my issue
