Anyone else having this issue?or my phone is faulty?when i try to launch and capture it will launch the camera app without capturing. The set up already on launch and capture.
try to repair your ICS installation via PCC.
mine is doing great:smileyhappy:
How your launching the Quick launch?
Quick launch of camera will not work if you open the App form lock Screen, It will take the quick launch capture when you press the manual camera button.
Thanks for the answer, it is now working after repair and not as laggy as before
