I am having problems with my SE Xperia Pro after upgrading to ICS. When doing a video capture using the camera function, I cannot end/stop the video recording. I have to actually kill the application to sort the problem out. Is anyone else having this problem or is there a fix available?
I would recomend
uninstall taskillers, antivirus and battery juice defendres (this apps cause more harm than help) -> restart your phone
settings -> applications -> manage applications -> all -> camera -> clear data
how did you updated your "Pro" to ICS if it hasn't been released yet, it will be available late May/June
if that doesn't fix the issue then repair your phone with
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Don't forget to backup
http://talk.sonymobile.com/thread/36355
Apologies, my phone updated seem to be to Android version 2.3.4. Sorry for that. But I am still experiencing problems.
I have tried and done all this. Removed all apps that I actually installed myself and still the problem exists.
I have the latest update for my phone I think. Android version 2.3.4 Build No. 4.0.2.A.0.62
try again with SUS and do NOT install any app at all, try to record a video (but after you repair your phone with SUS)
are you using a protective case?
what are your camera settings ?
I tried your settings -> applications -> manage applications -> all -> camera -> clear data and that has resolved the problem. Many thanks
Anytime
