Hi all,
I've bought a Xperia x10 a few weeks ago with great expectations, but it lasted with a huge disappointment! Whatever I guess I have to wait for 2.1 update but I amn't sure it will satisfy anybody. As I wrote in title there are some serious and annoying problems, I cant sign in my twitter account on the phone because of login and connection problem (however I didnt get any problems at signing in Facebook and Gmail accounts). Second problem is "missing" Android Market application on the phone, anyway I found the official .apk (vending.apk) from the net and loaded to my phone but it didnt work and caused freezing and error messages as "not responding / force to close" etc. Also I cant reach to Market site from Browser, no way!!! The last and stupid problem is "reseting and deleting" Browser setting and bookmarks without any reason or action like hardreset or even turn on/off the phone!!! As an example: I set homepage as google.com and later on I checked ok! but for the second use after a couple of time, when I started the browser it opens with SE Wap Page as default and removed my homepage from settings. Also phone deletes the Bookmarks which I add.
If there is anybody who had the same problems and solved afterwards, could you help me please?
The only thing I might be able to help with is the Twitter thing, I was having no updates on Timescape although my Twitter app was working ok. I deleted my account which I had logged in with using email and password. I then tried to re-apply the account but that too would not get me updates. So I deleted again and then re-applied using my @username rather than email and that seemed to work and I have been getting updates since.
Android market is not available in all countries. Your country may not support android market.
In case of browser I think you have installed some application that clears cahe and history. I haven't faced this problem.
