I recentley bought myself the Arc and while mostly happy with it, I'm having some issues: It seems that people I call sometimes have trouble hearing me, it is described to me as different kins of noise. Any suggestions on what this could be? Call quality on my end is usually very good when this happens. I don't think it is a problem with the recepient.
What also complicates the issue somewhat is that I have suspected it to connected to handover between 3G and GSM which happens in areas with poor reception. This thats time and is a problem when making or having calls. Still the problem seems to sometime occur when I turn of data traffic and wlan etc.
Any suggestions? I have looked for an update. (though there are none yet?)
if you don't want to use the backup & restore app then
"backup SMS" it will backup SMS/MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
backup & restore SMS
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use Save MMS
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
one last thing
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
