Today just apeared the messege that a new operative system was avaliable for my XA, I tried to update via PC Companion but it fails, on the second stage, preparing the phone, it apears a messege saying to disconect the phone, wait 5 seconds and plug it in again but holding the volume key, but it doesn't do anything at all. Any advice?
install seus and then restart your computer, make sure your phone its OFF before you hold down the volume down key
are you holding the volume key and then while still holding the key connect the usb cable and do NOT release the key at all
or try this
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Yes I was, and nothing happend
1.- What is that?
2.- what is the update?? Because Ice Cream Sandwish release is on April
problem in updating 4.0.2.A.0.62..
i dont have ARC S(LT 18) in that list, where i can find only ARC LT15. Pls advise
it's 2.3.4 but it will fix some bugs
are you using PCC or SEUS?
am using PCC..when updating got error message and asked me to retry. When i try, it asks me to select the model. but Arc S is missing in the list
