Hi Friends...... I am experiencing some issues after ics update
1-slow performance (hangs when I slide between menus or making selections):smileyplain:
2- Hangs when i am making phone calls/ incoming, messaging:smileyangry:
3- Low free ram 30 to 67 mb max.:smileyconfused:
4- unable to capture screenshot after update.:smileyconfused:
5- no message/ notification tones (it comes only for few days after update):smileycry:
I have updated my phone for at least 7 times......but no luck.:smileyangry::smileyangry:
I have always formatted my phone before update, with no backup ! I am not in a mood to give-up on this beautiful phone......please help
Sorry to hear about the problems your having with the update.
These issues have been discussed before in this forum. I recommend that you first check the existing threads for information and possible solutions.
Here are some examples of threads you can check:
http://talk.sonymobile.com/message/440001
http://talk.sonymobile.com/message/325115
http://talk.sonymobile.com/message/336706
http://talk.sonymobile.com/message/315130
http://talk.sonymobile.com/thread/55648
http://talk.sonymobile.com/message/350128
No reply.....!!
c'mon sony....:smileyangry:
Thank you Rickard, i have read the posts.......it helps me a lot, i have disabled some of deafault apps and now my phone is running smooth as butter...
Thanks again.
ye.. i had also faced the same problem.. the official ics released by xperia u do hab many bugs so better downgrade it to gingerbread. After downgrading it. the problem of freezing during incomming calls and imcoming message will be solved but the performace will be same as in the ics.
