hi,
i have a problem with updating my xperia arc phone. i will be very thankful if anyone can help me on this issue.
i was updating my arc to the latest software by connecting to the computer. while updating, my computer was rebooted(a blue screen appeared and it restarted) and the updated failed. i tried again, but this time the pc companion showed update failed. i tried reinstalling the pc companion, but still it doesnt work. anyone have any suggestions.
try this instead
Update Service (SEUS)
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
try this instead
if that doesn't fix your issue you can use Flashtool
Xperia Arc LT15i/a & LT18i/a 2.3.4 4.0.2.A.0.62 minor update
http://talk.sonyericsson.com/thread/29197
thank u very much. it worked.
anytime
Don't forget to mark Correct Answers & Helpful Answers
