The problems is not over.
I have a problem.
After I re installed the ICS again, I found that my phone calender is disappear.
I'm only the google calender ( I added picture of my problem)
Before I carried out the re installed of ICS' the calender have two option to save my events.
1) google callender
2) phone calender.
Now I have only google calender.
How can I to add the phone calender?
I need help with my phone.
thank you.
OK. after a lot of time of attempts, I solved the problem.
The reason of the first problem, it is come from backup.
After I did re installed to my phone, I restore my phone book and messages.
after I restore it, the problem is come back.
To solve it, I back up only phone number, messages, pictures and music.
I didn't backup settings and others.
After it the first problem is solved.
