Hi, I bought Sony Experia WT19i 1 week back. I have issue in connecting with mobile internet. If I disabled data connectivity and enable it again, it is conecting to internet and showing no internet connectivity.... If I restart mobile again, it is connecting. Can any one please help me in resolving this issue.
Regards,Bala
try to give it time to start after you enable it,
if not try to restore settings.
sorry for the typo, internet is not connecting if disable and enable it again
until restart mobile
To perform a settings reset do the following,
Menu > Settings > Privacy > Reset Settings
thanks for the update
Did the information provided resolve the issue?
What are your thoughts about this forum? Let us know by doing this short survey.
