i have a problem with the wifi of my xperia go, everytime my phone will be shut down and my wifi is turned on and connected to a server,i can't connect it after i turn it on.. it counts almost 7 days before it connects again. it always happen since i bought my phone. thankyou for the solution.
Keep us updated. Fingers crossed!
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
Hi, are you experiencing this issue with all Wi-Fi network or just a specific one?
i experienced this issue with any of those wi-fi network that i was connected, before my phone shuts down.
not yet..i will try it right away..thank you
thankyou for the solution.. my wifi is now working.. but i have a problem now after i repair my phone.. its been hard to touch.. i mean some of the keys (specially in typing) is not working., most of the letters wont function normally.. what can you advice? thankyou
That shouldn't be the case after software repair. See if factory reset helps.
