Hi All,
after updating my Xperia p to JB i cant see the weather forecast dont what happen to it it shows total black. what to do? any help?
Try to delete the weather app and hold on screen, select "Widgets" and select the weather widget again.
What type of weather widget do you mean? "News and Weather" or "Weather"?
Try to delete and select again
Activate GPS and see if something happens
Have you selected City?
Weather app, which is on Main Screen on 1st page
Thanks for the Support
its Working
Great! Have a nice day!
