hello,
i am having a problem downloading application such as games and others.
i have connected to the internet, i have tried downloading the apps but it didnt work.
could you explain it in detail??? tks:-)
you can take screenshot by on
if your on GB: press Power Button>screenshot
if your on ICS: press Power Button and Volume Down AT THE SAME TIME
there are only 3 options,airplane mode,silent mode and power off
you are on ICS?
im not sure,what is different between ics and gb?
this WAS the android market
now this Is android market/google play
check your version, settings>about phone>android version
android 2.3.2
okay i see. did you try to upgrade?? which of the photos above you have?
no i didnt, i have the first photo, i dont have google play, but i have PlayNow
but the third til the last photos are similar with PlayNow or playstore
oh I see, try upgrading to android version 2.3.4 if you could, it has many added features, such as the screenshot and the google play..
see status: http://en.wikipedia.org/wiki/PlayNow_Arena
