Dear viewers,
My Xperia SP is stuck in a loop. It works until the coloured waves and then it boots again. Is there any way i can boot the phone without losing the data on it?
Thanks.
AndroidUtrecht
My xperia SP is also having the same problem. Previously it used to reboot again n again and get on after 5-10 minutes and work as usual. But now its not even moving forward and getting stucked after the first wave. what might be the problem.....
Nah, m8 should have made a backup before rooting, you are lucky becuz its a softbrick.
USE XPERIA COMPANION
Its called bootloop, you must have got a system deleting virus or tried to root the device, softbrick scheme is :
Boot to *;-:7*;:+:-
Normal one:
Boot to romSP
