Hello,
I'll soon go to canada and I'm at freemobile(french mobile network operator). The roaming agreement between freemobile / bell / telus, is on the 3G only and the network uses 850 and 1900MHz. But my ST27i operates on 3G 900/2100MHz.
The ST27a operates on 850/1900MHz.
So my question is, is it possible to change the 3G operating frequency of my ST27i by flashing the rom, or some other miracle solution?
Thank you
Patel.
PS : sorry for my bad english 😉
Hi there,
It's unfortunately not possible to change the broadcasting frequencies since it requires different hardware radio parts for the different network standards.
Ok, i'll have to buy a new phone...
Thx for the answer.
