Plzzzzz..!!!!!! somebody HELP ME....~~~
Today acsidently I removed my full data files with apps from my System. I did that with root explorar but after that I moved full data files from System to my SD Card... I'm really so stupid that's why i did this... then swich off my cell and try to on it again... But now it's just Re-starting again again... not working yet... And finally I realized that what mistake I done... but Thanks God.. I still have those data files on my SD card...
So does there have any Cordial person,, who can help me in this situation.... plz!!! anybody just let me know.. what I should do to prevent this disgusting problem...!! plz get me some ideas.............
well the software will tell you what all to do
if still you face any problem we all are here
use Update Service to repair your phone
Thank You so much Mr. Uliwooly.. Can You plz get me some idea how I would able to slove this problem practically.. I mean, what actually I would have to do with my cell phone... can you plz kindly tell me details.???
Thanks a lot for your Kind information,,,Now I'm downloading that update service setup...But I'm a little bit Confused, that what I would have to do after download this file..! Can You plz kindly get some idea how I would able to slove this problem practically by myself..??? I mean, what actually I would have to do with my cell phone... Plz Kindly tell me little details about repair my phone.. This is Sony Ericsson Xperia X10 mini pro...
Thank you once again for your kind help....
:smileyplus:
I'm writing here again to give you thnaks.. cause I already did it and able to repair my problem...
:smileygrin:
Thank You so much SlimShabby.......
Wish You all the best~~~~ :smileyplus::smileywink:
hmm
