try to use Update Service or PC Companion to see if the update it's available on your country/network
Install it and you will see 5 folders
This is an step by step guide
5.a. Unplug your USB cable from the PCb. Power off your phone and plug the USB into the phone
c. Press back button and keep your finger on button
d. Plug USB cable into your PC whilst holding down the back button on your phone
e. A green LED will appear
f. The process will automatically detect your phone and start flashingg. When "Found at USB/........" appear on flash tool you may release"back button", sit down, relaxand wait.Hope this is helpful to you6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
Regards,
Ricardo Rendeiro
other ways to backup your phone
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
this is how to use Flashtool (videos)
I already have flashtool, but I do not have firmware 2.1. where i can get firmware 2.1 ?
where i can get x10_1.0_SE_StockRom_MultiTouch.ftf ?
