Hi, i know how i should delete them, i just hold my finger on shortcut for few seconds and drag it to the recycle bin at the bottom. The problem is, even when i do that, the shortcuts stay where they were.... Any suggestions?
If Slimshaddys instructions do not help then try the following,
Menu > Settings > Applications > Manage Applications > All > Homescreen > Clear Data.
This will remove all apps from the screen.
restart ur phone then try..
It really helped, thx
Any time, glad I could help.
Jake,
could you please take time to answer my question about the 2.3.4 update.
It has been up for a couple of days and it is a really simple question and i am surprised no one from SE has answered it on any of the channels (youtube/SE Blog/SE Support forum/SE facebook).
Go to settings. Display. Homescreen. Turn off 'Lock homescreen layout".
Go to Settings
.Display
Homescreen
Turn off "Lock homescreen layout".
I hope this helps!
Mary
