why the application downloaded is installed directly to phone storage?? we don't have option to choose install to micro SD?? how to?? it makes me cannot install many apps in my phone
no you can't, that's only for Android 2.2 and above
unrelated topic, if you have some time please check this thread
if you want 2.2 or 2.3 here are the alternatives
http://forum.xda-developers.com/showthread.php?t=1379754
http://forum.xda-developers.com/showthread.php?t=914513
2.3.7 Custom ROM for Xperia X8/W8
http://code.google.com/p/minicm/downloads/detail?name=MiniCM7-2.2.1-shakira.zip&can=2&q=
if you want apps2sd you can use this
if you want apps2sd feature on your phone do this
http://forum.xda-developers.com/showthread.php?t=800555
or you can use Link2SD BUT you need to root
to root you can use superoneclick
http://forum.xda-developers.com/showthread.php?t=803682
