Hello I have a Sony phone lt28h unlocked i Purchased from iraq, but my phone stopped receiving the network after two months I entered Turkey.
please help me find a solution to my problem. Peace
Topic edited by Rickard
I don't know - This sounds like an issue between you and the networks - Phones don't work fine then after two months stop on different handsets
You need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
the imei Locked by the service provider in Turkey, because I have not bought the machine from Turkey note that works on any other company outside of Turkey, what is the solution?
Maybe the network bands are different
Not been working for two months and then stopped and used a second phone and also two and stop? What is the solution
Have you paid you bill or got credit or the phone may have been report lost or stolen and as such blocked
No pre-paid SIM card and purchased a new phone from the company and is not inhibited
Is there a way to change my imei To another Turkish imei from Old device?
No that's illegal - You need to have your device inspected but I don't think it's the device at fault but the country
So what to do I change the country Hahahahah? Is there another solution?
