Hello
I have all my contacts in my old phone, it's a nokia n96.
I have seen the page where you can send a text message to your old phone and it will help to pass the info, but my number was already moved to my new sim. So I cannot use this service anyone knows of any other way to pass my contacts and photos to my new phone?
Thank you very much
A few things you can try:
Let me know what you try
Thanks you very much for your help I used the bluetooth opition and it worked perfectly!!
The only little thing is that I have to save one by one. When the phone passes the contacts I then have to accept them basic like if it was a message. Any new brilliant idea?
