I Have a question to ask SE again about the X10.
Why does the battery in my x10 last for ages when i switch to airplane mode.
And when i say ages i mean longer than a month on standby.
Versus the maximum 2 day standby when airplane mode is off?
you can use a 3rd party battery, they are really big but it will double your battery life for sure. regarding better signal, if you are not using 3G/data you can turn that off and only use 2G for SMS MMS and phonecalls
you can download a widget to do so
or homescreen -> menu -> add -> widget -> data traffic
Actually.. 2G is completely phased out here.
only 3G works.
sorry to hear that
