Hi, I am new to this forum. I have recently updated to ICS 4.0.4.
now I am facing a problem while dialing a number. it says "Unfortunately, the process com.sonyericsson.android.socialphonebook has stopped"
I dont need numbers from social phonebook, just want to dial some numbers, but its not working. Kindly help on the same
Repair your phone with SUS > uninstall mcafee, do not install any app just test it.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
unrelated topic, if you have some time please check this thread
if you have a taskiller or antivirus, it's probably acting up. uninstall mcafee and any other taskiller, antivirus, you don't need them.
Thanks Uliwooly for your fast response.
But i tried your suggestion, nothing has changed, same error is flashing again and again. Infact I had KIS in GB. It did not cause any problems there.
