I just upgraded from the x10 mini pro to the latest mini pro. One thing that's bothering me is how on the first screen (with the unlock slider) it shows notifications for missed calls and text messages. I use apps other than the original ones to deal with these functions but even if I have read a message in Handcent or looked at the missed call in Dialer One the only way to make the notification disappear is to go into the original application and view the message or call. Is there any way to change this behavior?
My x10 mini pro never had this issue. If I read the text in handcent then the notification would go away.
Thanks in advance, everyone.
that is correct you can not disable the lock screen notifications
go to message > press menu button , select settings and disable notifications..see if this helps..
Nope, that sems to only effect the taskbar.
Thanks
there is a way to do so
1) root your phone
2) titanium backup to delete this app
*CoreNotificationPublisher.apk --- Lock Screen Notifications
you can read more about it here
http://forum.xda-developers.com/showthread.php?t=1089470
don't forget to mark the Correct & Helpful Answers
