Since getting this phone I've been on the web all day trying to figure out what some of the notification icons mean. Sony needs to update their manual or make it more intuitive (like if I slide the notification page down EVERY icon has a corresponding description).
I finally solved the 'stamina mode' one. Not in the manual.
And this one has trumped me. A wrench in a circle... see attached. Thoughts to what it is?
that's from an app that you've installed.
How on earth did you figure that out? That's exactly it. Thank you!
because I'm awesome, that's how
