When i download from Getjar(its giving free apps this holiday) after download finishes b4 installation it shows not enough memory while mine has bout 250 mb free..:( any suggestions??
thnks in advance!!
crap..
ok. settings > apllications > storage use > market
clear data and uninstall updates....
go to settings -> storage -> under Internal Storage
how much Available space do you have?
also download apps2sd , it clears cache files which increases the internal memory..
done it..cleared nearly 18 mb...bt still same issue
wen i asked this question i had around 250 mb free there...now after installing some games it bcam 178 and after clearing caches now i have 201 mb..:( and still dwnloading frm getjar shows i have low internal memory..:'(
thanks...this worked
now i have 75 mb free n still then i can download n install without any roblem...was a weird problem i guess
great
btw Happy New year buddy..!!
happy new year :smileygrin:
