Sony promised about Smart Social Camera app in new update but i don't see that
what can i do ?
That is weird. I tried it again just a few minutes ago, but mine is working ok.
Is everything ok with your network connection? Maybe it just can't connect to Sony select store or something?
Did you get the same Camera layout as in this picture?
If you did, than there is a Apps button on the top right corner, which starts Smart Social Camera App store where you can choose and add Camera you would like to use.
If your camera doesn't have this camera layout, then something is probably wrong with your update.
I haven't social camera also...tap on app icon will send me to Sony select and there isn't social camera to download
social camera is for z series not the sp yet so is onfo eye app
