hi,
i need your help my xperia SP cannot detect my sim card,
what should i do?
it could be a software issue
repair your phone with either PCC or SUS if that doesn't work, get a new SIM card if that doesn't work then take your phone to a Sony repair center
few things might be the reason
1. you had a regular SIM card and you cut it, you will need a brand new MICRO SIM card
2. if its a micro SIM card it might no longer work, it happen, get a new Micro sim card.
i used micro sim card.
but when i use it to my other phone sim card it's fine.
is that possible that i have hardware problem with my SP.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
thank you for your help.
it works fine now
Regards,
Andre
anytime
Hi,how do you solve the problem at the end? my phone always meet the problem,I feel so sad,could you please tell me the ways?
check the above suggestions
I tried all the suggestions above and no success. I notice on other forums that their is a known issue with SIM not reading error with Sony SP. So maybe they will supply a fix soon. Will be off to the support centre tomorrow.
