how to rotate the desktop and menu icons in landscape mode but when it comes to the charger? it's a setting?
thats the setting, it cant be changed. using a separate launcher may remove that problem if you want.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
