using a new GO that I upgraded to 4.0.4 from Sony's website. (Not going to root it or anything - company phone). My problem is that according to the user guide there should be a mic button during calls to be used for muting. But there isn't . Not sure if it's related to the upgrade I did. Did someone experience the same problem, or am I doing something wrong?
Brgds
Call someone. Then you can see this right?
the third icon from left, under End Call. Tap this icon, mic will be muted.
Mark correct answers.
OK, now I get it 🙂 What caused the problem is that I had opened the keypad during the call to enter DTMF. By doing so the mic icon is replaced by another icon, hence my confusion. Thanks!
