I guess this is where the Nokia Phones score over Sony. I bought an Xperia Mini Pro and when I was about to send a friends phone number to another friend of mine,
I realized that Xperia mini pro diesthave the sending business card option. Can someone help or guide in case it does and I missed it. Or can the next softwar update have thisfacility/option as it is real handy a lot of times.
Thanks,
A
If you have access to the Android market you can download Contact Sender, which does what it says or an app called Handcent SMS texting app. This allows you to send a contact via sms. Its actually quite a cool texting app, allows you to save MMS to SD card and lets you select music for notifications, not just the android ringtones preinstalled on the phones.
