I have Sony Xperia SL L26i. I recently changed sevice providers. With previous provider I could use Data. Since having a new provider, I have not been able to use data. I have checked my settings and all are correct except when I come to the APNs page it only shows a settings symbol and the letters APNs, the rst of the pagee is tottaly blank! There is no Plus sign or anything.
I have reinserted my previous Simm and it shows two APNs. Can anyone advise your help would be appreciated
ric
Hi @RudyBritt and welcome to the forum!
I created a new topic from your post.
On the Xperia SL you need to tap the menu key (number 8 on the image below) in order to get the option to add a new APN.
However, in most cases you can automatically download the APN settings for your new service provider in Settings > More > Internet settings, or Settings > Xperia > Internet settings (depends on the Android version) so I'd recommend that you try this first. It may save you the work to enter the settings manually.
Thank you Christofer.
Your second suggestion fixed the problem. Had sent email to provider but no reply 5 days
I'm glad to hear that, you're welcome!
