If they are going to follow a pattern then you will have to wait for the rest of the 2011 xperias get ICS then the 2012 xperias and then I'm assuming they will fix the issues with 2011 Xperias ICS.
You won't be able to find an answer on this, as you won't be able to find an answer as to when the 2011 Xperias are getting the ICS or when the 2012 will get it.
