I faced Network Problem on Xperia Arc s after flashing android 4.0.4 with flash tool. When my phone start my screen make black but when i push lock key it show light phone make open but network error. I cant call anywehere. But network logo show full network. but when i make call it show network error. When i make restart it make right for 2 min but after 2 min it make same as network error. plzzzz help
just reflash your phone again if that doesn't work then it seems like a hardware issue.
ans plzzzzz
Find Sony Update Service, download and install it, then follow through the process to repair your phone. It won't downgrade your phone and is fairly self-explanatory.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
it doesnt work same prob here...:(
most likely its the SIM card, I've seen so many times.
get a new SIM card
also do NOT install any taskillers, task managers, antivirus, ram apps, booster apps, battery apps.
and double check the APN settings
its not work also. plzzzz help
do you have a data plan? do you have the correct apn settings? did you avoid installing those apps above? is it a BRAND NEW SIM CARD?
yes i hace a credit to call and i avoid athose apps and my sim card id perfect. My sim card work on another mobile perfectly. But i faced prob in my arc s. Plz help
get a brand new SIM card, just try it, get a brand new SIM card
