HI,
I've been having the some problems with the screen alignment on mine X2 since I had one spot on my Xperia X2 screen that was dead, so can someone post the calibration data please?
Thank you,
Sujith
Hi Markus,
Thank you for trying to extend your helping hand to me..
For geting the registy values, you have to install either Remote Mobile Registry Editor in your laptop / desktop or you need to install a Registry Editor in the xperia x2.. It is better if you can install the appication on laptop and accessing the registry from the laptop, becoz it is in bigscreen and modification can be done easly..
1) Remote Mobile Registry Editor for lap top / desktop (Free)
You can download the software from
http://mobile-registry-editor.en.softonic.com/pocketpc
This is a zip file, simply extract it.. Then please connect the xperia x2 to your laptop / desktop, the active sync will be connected automaticaly bydefault, now we can start the Mobile Registry application,
Expand the HKEY_LOCAL_MACHINE >> HARDWARE >> DEVICEMAP >>
Right click on TOUCH and slect export and save it, then please send the file to me..
There are three or four values inside the Touch key, CalibrationData, Driver, **Err something
2) install a Registry Editor in the xperia x2. (Free)
Download and install the application on the xperia x2 and open it
http://www.freewareppc.com/utilities/phmregistryeditor.shtml
Expand the HKEY_LOCAL_MACHINE >> HARDWARE >> DEVICEMAP >> TOUCH and make note the values and please sned the values for me..
Hope you can provide the values very soon! thank you, Markus
Regars,
Sujith
OK, here are the values I got:
"523,512 163,888 161,127 894,141 857,880 510,883 515,135"
Let me know if you need the exported "touch" file. I have it here if you do. PM me your email address and I can email it to you if so.
I really hope this works.
Let me know!
What do you think about this forum? Let us know by doing this short survey.
Hi Markus,
Thank you very much for sharing the values.. I will try with these values later today as I am in the office now and will update you tomorrow..
Once again thank you for your support..
Regards,
Sujith
Hi Markus,
Thank you, Thank you, Thank you.. It did the trick..
Once again thank you for your time, Markus..
Regards,
Sujith
sir can u email to me the "touch" file.... i have roblems with my align screen. tnx so much
Based on the below conversation in the forum I tried the same in my x2. now my touch screen is not responding. when I try to start my phone it is loading upto align screen and getting struck there. can any please send me the snapshots how to enter the calibration in remote mobile registry editor and also touch calibration data value to me. Thanks in Advance,
Regards,
Naresh
Hi Markus,
For getting the registry values, you have to install either Remote Mobile Registry Editor in your laptop / desktop or you need to install a Registry Editor in the xperia x2.. It is better if you can install the appication on laptop and accessing the registry from the laptop, becoz it is in bigscreen and modification can be done easly..
2012-05-09 09:12 AM
hi i have a problem to my xperia x2 about the alignement of the screen,i cant open it,,tnx, can you help me please
please give me all files inside that TOUCH folder and i ll manually configure your tutorial , where is the link of all the data for me to paste inside that TOUCH folder thank you
i succeeded with a needle center pointing the target + without touching the phone landscape with keyboard, make textfile first! welcome.not = 0byte and CalibrationData.not = 55bytes inside type this 523,512 163,888 161,127 894,141 857,880 510,883 515,135 in your sd e: , then off the phone, turn on, do spider hard reset press and hold the Windows key and letter O while keep pressing the (-)volume key ,press it when it lights before the sony logo come out. from now on i will make a back up first before custinizing it.
