plz help,my xperia u side lock button is not working,also camera is giving error and is not starting.
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
or
