sir,my xperia tipo wont start......
When I push the (power button) then mobile (vibrate) only,when i puch (power botton+vol-) then (green light) flashing,when i (push n hold power botton) then it (vibrate repeatedly)...but no start no screen display finally....
for this,
i try to connect with 'pc companion'....
device connected and 's1 boot download' driver works...
i try to go 'support zone' and going to 'phone update' but there "how to connect" tips show.....
sir,what i do.....
Sorry to hear about your problems.
You can try to repair the phone software using PC Companion:
In PC Companion, click start under Support Zone > start under Update phone > select Repair phone (in blue text) > Do all this without having the phone connected to the PC. Remove the battery from the phone for a while to make sure that the phone is turned off.
Then follow the on-screen instructions given to you in the program.
You can also try to do this with Update Service instead:
http://www.sonymobile.com/global-en/tools/update-service/
What are your thoughts about this forum? Let us know by doing this short survey.
Wow It works with charm
I m fully frustrated from last 4 days, I think i hv to go to service centre but ur idea give me a split of light in hall of darknesss.................U r juz awesome :smileygrin:
Thnx a lot
thanks for this post it really save my phone. i also have the same problem and i was able to fix it because of this post thanks xD
I have the same problem, when i try to turn it on the phone just vibrate and doesn't run the sony logo just vibrate.
when i press the + volume only showme the green led.
i try to restore in the pc companion and doesn't find my phone, the same history in the SUS.
please help.
I have the xperia tipo st21a
Try to remove the SIM card and SD card from the phone to see if you can start the phone. Otherwise it seems like you should have the phone examined by a service center. Please contact your local support team for more information:
hello
I tried this but there was no option for repairing my phone, i think this is because of a different software version
Please help asap
anyone know a solution ?
i have a unlock bootloader if this helps
please help
