Hi there!
I recently bought an Xperia SP and had it unlocked fully so now i can use any SIM.
But it seems that there is a problem: my phone is slow. I only have a handful of apps installed, nothing is programmed or working in the background or Sync is turned off.
I checked the OS and it is still stuck to Android 4.1.2 but the official Sony Mobile website says the latest is 4.3.
Is there an app to help speed up my phone?
Why is my phone not detecting the 4.3 update?
Please advice. Thanks.
hello
where do you live??
check here see if update unleashed in your country
http://talk.sonymobile.com/t5/Xperia-SP/Xperia-SP-4-3-update-availability/td-p/471259
do you have any antivirus task killer battery saver or apps like this?
Hi gino76ph
phone speed on processor not on any app
>make sure you dont have any task killer app, check in settings -> apps -> running -> is there any app which you are not using it but still running in the background(not the app which is pre installed on phone, so dont do anything to those)
>next do ;you have any app which has high end graphics used ?? if so try to remove it and check it
>do you have Chrome installed on phone ?? some users said this is causing phone to get slow so try to remove it and try it
let us know
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
hello
where do you live??
I had made sure there are no tasks or apps running in the background. I have no anti-virus or tasks killer apps that are installed as i know they themselves are the casue of the slowdown.
I'm curious as to why Chrome will slow down your phone? And does it drain the battery as well? What alternative browser can you giuys recommend?
I'm from the UK btw. It does say Vodafone & O2 but that is irrelevant as although my network is EE my phone itself IS unlocked. And the Sony Mobile UK website DOES say 4.3 is available. Doesn't make sense to me at all i'm afraid.
Well try to disable something in the phone like the application which come whit phone I mine, if you don't use it and I think half of team are in standby mode
you can disable in settings - application - all application
I did and like get free space in phone and got a free ram ... Try maybe will help you
Yes chrome problem reported my many users..you can disable it not uninstall...dolphin browser or Firefox are good
And update didn't hit uk unbranded
I shall disable or uninstall Chrome ASAP.
Any other suggestions please?
reset your phone regulary..after 2 days or when you fell phone get slower..that will help for better performance
cause after some day ram overload with apps and performance will decreased
and disable apps you wont to use setting>apps>all
DONT disable apps that you dont know what is
Hi gino76ph
Actually latest chrome had some bugs which tend to absorb processor speed of the phone, many users said that, being said so any other sony users face this problem we tend to give this solution, amazingly it worked for many!!!, so it was a twitch we give it to you,
BTW the browser i use is firefox but i dont use often to be honest, i use browser which came along with my phone, it wont lags or nothing,
my battery back up is good, i can use my phone for 2 days with out any problem :):)
Manjuboyz
NOTE:
I understand Chrome slows the phone down and sometimes apps that run at the background slows it all down so i will follow those advice.
But it still not a comfort for me that software/firmware updates does improve the phone and still no sight of Android 4.3 on my phone.
Updates and optimisation will work miracles for Sony. Only if they do it.
