So,i have the system update "alert" that inform me about a new "4.0.2.A.0.62" version update, and when i connect my phone to the PC with the PC companion ,it shows me some steps to update it,but it doesn't make sense,everything i do it does not working and do not updating.WHat should i do? is there any other way? help please.!
Thank you for your time
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
or
thank you :smileylove:! that worked just perfect in contrast with PC companion :smileyminus:,which i couldn't succeed.
:smileygrin::smileyplus:
