I were using fast boot to open CWM to install Superuser.zip
But after I Finished And reboot my phone , my phone Enter Again to CWM and does not want to boot to the system
Please , Any one Help Me How to Resolve That
Thank U Very Much
Make sure any of your key is not stuck inside
or you are left with only 2 options
1 flashtool
2 repair using pc companion
Can you tell me you are on which firmware, and your mobile
Take the battery out and reinsert it after 1-2 minutes..
if it enters cwm again then select reboot from the options and see if you are able to make it,, make sure you don't press any key and all keys are relased ( free )
Thank U For Ur Help
But It still go to CWM
Thank U Very Much
i were already trying to flash it Again by flash tool but it was getting me an Error
But After Alot of tries .. it succesfully flashed
Thank U Very Much For Your Help
