hello,
does xperia s music player compatible with xperia x8 amd xperia x10 mini??
thank you..
no, you need to have ICS to be able to run it
hmm...do you have any xperia's music player that can be fitted to xperia x8and xperia x10 min?
I don't, but check the XDA Forum
