two options either download another music player or change the format of your music files on your PC w/
FormatFactory
Thanks, most excellent. I just downloaded poweramp and it works perfect. Uninstalled stock player.
Thanks again.
http://mediago.sony.com/enu/download As an alternative, you can also use Media Go to transfer your music tracks from laptop to phone, as this application encodes the transferred files into a format compatible with your phone.
anytime but I prefer to use Music by google, if you live in the US you can test drive the cloud part of the app
https://market.android.com/details?id=com.google.android.music&feature=search_result
