Discussion #257871 never resolved the OP's problem and now I have it too. My Outlook.com calendar recently disappeared from the native Calendar app on my Xperia Pro (4.0.4) and my Outlook.com account became invisible in Settings: Accounts & sync, but was still present because Android told me that I could not add it as I was attempting to add a duplicate account.
I removed and re-added the Outlook.com account via the Outlook.com email app, but now every time I open the native Calendar app, I have an extra unwanted phone calendar in the default account. I currently have five six! It seems that the Calendar app isn't satisfied with my syncing and showing the Outlook.com calendar, nor is it satisfied with N phone calendars - it always wants N + 1!
I can collapse these unwanted phone calendars back to one by clearing the data from the Calendar and Calendar storage apps, but this results in my having to re-add my Outlook.com account and in any case it doesn't stop the phone calendars from breeding. I feel like the sorcerer's apprentice.
Is there a specific sequence of steps that will fix this?
The Outlook.com problem appears to have been caused by recent server instability.
It seems that my Calendar problems were not directly related to the Outlook.com problem, but due to my reconfiguring the Calendar over-zealously.
I recommend:
have you tried to check on the accounts settings?
I recommend:
