Then this generally indicates that the settings are wrong. I can only advise that you contact your network carrier and ask that they supply the settings manually.
You need to download internet settings first Settings-more-internet settings.
Hi JaysonVevo,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
After performing the settings download, did you get a 3G or H or even a G symbol beside the signal strength?
I see, Im glad you managed to get this resolved. I hope you have no further issues
