I'm assuming (foolish I know) that the Arc supports Micro SD HC cards...
The tech spec states up to 32GB but only says Micro SD.
To my mind a card of over 4Gb is by its very nature HC, but woudl like to be sure before I go and buy one!!!
Thanks
Cheese
http://talk.sonyericsson.com/message/63691#63691 You are correct in what you say and this related thread confirms it.
Thanks!
That's just what I was looking for but couldn't find the thread!
Blooming newbies!!
Cheese
No worries.
