After I update my Xperia V(LT25i),my application for "Messaging()" was deleted from my phone and now I don't have any application for send or receive my Sim card messages
I must tell you before I update my Android I update my messenger and I think it's deleted because of that,
so I need your help,and if it's possible send that Application.
Thank you.
Download sony update service and repair your device:
http://www.sonymobile.com/gb/tools/update-service/
Go to settings-apps-all-messages,enable it.
Thanks,
But I don't have any application in this name...!
Hi A_REZAIE68,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
With the information supplied, I can advise that you will not find Messaging under M within All. You need to scroll down to the very bottom of the All tab and find messaging and Enable it,
Menu > Settings > Apps > All . Scroll down to the bottom > Messaging > Enable.
I hope this helps.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
