Is it possible to customize the message tone on the W760 like you can the ring tone, or are you stuck with the 8 or so canned sounds that S/E provides?
Thanks in advance,
Sean
If you go to settings then sounds and alerts then down to message alert you will see you can replace one of th alerts with your own sound.
Perfect - worked like a charm! Thanks, mate.
Sean
Glad I could help.
