Dear Sony staff,
I'm Thomas, I'm from Vietnam.
Two days ago, I bought new Android Cell phone ST15i from Store in Vietnam.
Before that, I viewed specification of this phone, specially Memory.
Memory is 512MB, that's so great.
But.... when I got it, total memory, my phone has, is only about 305MB. (You can see it on the following photo)
Is it normal? if yes, could you show my how I can see all memory of my phone?
Thank you very much.
Hi, your phone indeed comes with 512MB of RAM, what you see is the available RAM for user. The remaining RAM is dedicated to OS functions.
Thanks for your information!
Hopefully, Sony will show more details.
By the way, is there any way for me to upgrade memory of cell phone in the future?
Unfortunately you can't.
